Solutions
Remote Monitoring and Management, Under Your Control
Spot problems early and act from the same console. SimpleHelp combines live monitoring, custom alerts, scripting and remote access so IT teams and MSPs can keep machines healthy across customers, offices and locations.
What is remote monitoring and management?
Remote monitoring and management (RMM) brings together two jobs: watching the health of your devices and taking action to maintain them. Monitoring tells you which machines need attention. Remote machine management gives you the scripts, tools and access to do something about it.
Turn insight into action
Move from individual support calls to a repeatable maintenance workflow. Monitor your estate, define what needs attention and give technicians a direct route to a fix.
Monitor device health
See CPU, memory and disk usage alongside machine status. Group devices by customer or purpose so technicians can find relevant machines and investigate resource pressure before it disrupts more work.
Create alerts that fit your environment
Set up alerts for the conditions that matter to your team. Use custom scripts to check application-specific requirements, then connect those checks to the way you respond.
Automate routine maintenance
Run tools and scripts remotely, schedule recurring tasks and take action in response to events. Deploy files and resources across groups of machines to reduce repetitive hands-on work.
Connect when a closer look helps
Open a remote control or terminal session when a task needs investigation. The same platform supports background maintenance and direct assistance, so technicians can choose the right approach for each issue.
One workflow, from alert to resolution
A disk-space alert flags a machine that needs attention. A technician checks its diagnostics, runs an approved cleanup script and verifies the result. The team can then schedule suitable maintenance for similar machines, rather than repeating the same investigation one device at a time.
SimpleHelp fleet view showing organised remote machines, online status, CPU usage and memory usage.
Machine status and resource usage sit alongside the tools for connecting and taking action.
Make the trial match your real work
Start with a few test devices and a workflow your team knows well.
  • Group a small set of test machines by customer, role or location.
  • Create an alert for a condition you can safely reproduce.
  • Run a maintenance script and schedule a routine task on your test devices.
Explore all SimpleHelp features →
Your questions, answered
Is RMM the same as remote access?
Remote access lets you connect to a machine. RMM adds ongoing health monitoring, alerts and repeatable maintenance across a collection of machines. SimpleHelp brings both into one platform.
Can I use my own scripts for remote machine management?
Yes. SimpleHelp supports remote tools and scripts, scheduled maintenance and custom script-based alerts. You can build on the scripting languages and operational checks your team already uses.
Does SimpleHelp offer AI assistance for management?
Cyana is an optional AI add-on for fleet diagnostics, tools and automation, as well as help inside remote sessions. It supports a choice of AI providers, including on-premise models, with technician review before changes are made.
See what proactive management looks like
Put SimpleHelp to work with your own machines and technicians. Every feature, free for 30 days.
Start Free Trial
